1 - 11 of 11 Posts
Ducati Streefighter S
Hi to all,
I would like to instal a quick shifter on my bike, it's an SF 1098S year 2009.
On Ducati performance parts I have found the product but in the description it says that it fits only for 2012-2013 S models.
Does anyone knows if this will work on 2009 model ?
Also, what is the difference in '09 and '12/'13 models ?
Thank you
BR
No it won't fit dash and harness aren't the same. You need an aftermarket one with the control box.
Ricko...tnx for the answer.
So I need a Power commander 5 + quick shifter
I know the PC is a reliable unit but the design is decades old and lack adjustability. I have been looking at the Annitori and it seems like a better option and you might want to consider it.
I would recommend heal tech, easy to install, adjustable with your smartphone when you get the app. Works flawless. At least for me.
A proper Power Commander V + Autotune setup requires you to re-flash the ECU first. By the time you complete this step it is very likely you've already forgotten that it was Quickshfiter that started it all.
Discussion Starter · #10 ·
I have aftermarket ECU, and according to threads that I have found on this subject it should be "open".
Used to have this setups on my previous bike and I was very impressed with the performance once the AFR was set up properly.
1 - 11 of 11 Posts
