I have a 2000 996 and I have adjusted the idle up 100 rpm by moving a stop screw located near the throttle bodies. It looks like it just prevents the throttle from closing by adjusting this screw.
Is this the correct way to adjust the idle ?
Also if this is the correct way, will this way also work on the 999 ?
(A buddy has a 999 and needs his idle adjusted but I have yet to look at the 999 with the fairings off to see if this is an option) I don't want to adjust someone's idle this way if it is incorrect.
Thanks in advance :D
comrade moderator
You can't adjust the idle on a xx9 bike without cutting a hole in the top of the airbox.
If you want to go for it (I did), use a 1" hole saw and cut a hole in the top left rear corner where it rounds down. It will take a long 4mm hex wrench to reach the adjustment. Slap a piece of duct tape over the hole when you are done.
I've been told you have to use the mathesis thingy to do this, and what I did was wrong. Whatever...it worked great for me!
don't go cutting holes!!! my service tech adjusted with pulling little rubber plugs out .bike running with the left side fairing off and a long screwdriver.you should use the mathesus box for proper mixture
