1 - 19 of 19 Posts
G'day, just joined the forum, after deciding I could do the 30,000klm service myself. I have a 2015 Multistrada S with the DVT. I am reasonably confident with changing the timing belts and measuring the valve gaps, I will have to do some more YouTube viewing on actually changing shims. I have a 1971 Kawasaki kz 650 which has the shims underneath the buckets so camshafts have to be removed to change shims (What a good idea).
I have been busy ordering gear I will need for the service ie plugs air filter oil filter oil belts etc.
One question I have already is about resetting the warning lights on the dash. I currently have an OBDII scanner code reader which I have used on my car, from what I have been reading so far I can get a lead that connects to the OBDII reader to the ECU via the 4 pin plug on the bike. Will this setup be able to clear the codes. My OBD reader is powered by the vehicles battery via the 16 pin plug, I can also fire it up via a usb plug on my laptop. Most of what I have been reading involves a bluetooth OBD reader, any advice greatly appreciated, regards Neil
From my own research and what I've read here, there is no way to reset the service reminder on a DVT without buying a professional level diagnostic computer.
Since I did nit found how to reset the service warning I simply changed the date and the warning disappears. To do so you only need to enter on the bike menu, go to date and change the only the year into an old one, I set 2019.
The hour remains the same so nothing important changes because the year and month are not visible on the dashboard unless you look for them entering through the menu.
There are two factors that can trigger the service light, elapsed time and mileage. The date change trick may work when you have the service light on due to the elapsed time since the last service but I doubt it would work when you hit the mileage limit.
So latest update, doing a proper 30,000klm service by the book, oil, filters, brakes, belts, valves etc. Oh what an adventure it is turning into. It is a brute of a bike to work on, besides getting the plastic off, which is a challenge in itself, that is only a prelude into getting the deep spark-plug connectors out. What a PITA that was for both pots. I have worked on some frustrating old vehicles back in the day when to get a true valve gap the vehicle had to be idling and you had to have 3 hands to adjust the gaps with ring spanner screw driver and feeler gauge all going up and down at a gentle idle speed. (Pure bliss compared to working on this thing). So I have the new belts on and now I want to check the gaps for the valves, I do what the manual says but when I look at the picture within it shows the cams with the belts off and the cam securing journals off. Why is this, if you want to check the valve gaps why not do it with everything in situ and hopefully if everything measures OK you don't have to change any shims. So my question is " can I do the measurements with everything as is then only take off the belts, cams etc to change shims?
Sophomore Member
Yes, you can check valve clearance with belts on, but if you are changing belts anyway, do it before you put new belts on. It sounds like you already put new belts on. Go ahead and check valve clearance with each cylinder at top dead center.
Discussion Starter #7
Thanks the info was very helpful unfortunately I think I might have bent a valve as one of them is waaay off the limits.
Discussion Starter #8
G'day, I marked all the belts and sprockets but still managed to get them out of sync. I was turning the rear in 6th gear very gently and I felt the valve touch the piston, as soon as I felt it I backed it off and tried to figure where I stuffed up. Not to worry I know the valves must be very delicate but I don't think I did any damage, welll I hope not. I removed the belts and sat and looked and tried to figure it out logically. Refered to the workshop manual again and thought that even though it has DVT it is still basically a 4 stroke engine ie (Suck-Squeeze-Bang-Blow).
So set the horizontal cylinder to top dead center, presumably on the compression stroke. Set the cam marks level with the head. The vertical pot is already going down on it's inlet stroke and I put the marks on the cam wheels level with the head. This is where I had to go against the spring on the inlet valve but with these DVT there is a big handy allen key hole on the end of the sprocket. lock the cams and fit the belts. Well that's what I did and it turns over without any valve/piston interference. Measured valve gaps and this is what I found.
HORIZONTAL CLOSING.
Left Inlet. .152 mm/.006 thouRight Inlet. .254mm/.010 thou
Left Exhaust .102mm/.004 thouRight Exhaust. .102mm/.004
HORIZONTAL OPENING.
Left Inlet .178mm/.007 thouRight Inlet. .152mm/.006 thou
Left Exhaust. .152mm/.006 thouRight Exhaust. .152mm/.006 thou
VERTICAL CLOSING
Left Inlet.127mm/.005 thouRight Inlet. .076mm/.003 thou
Left Exhaust. .152mm/.006 thouRight Exhaust. .102mm/.004 thou
VERTICAL OPENING
Left Inlet. .178mm/.007 thouRight Inlet. .127mm/.005 thou
Left exhaust. .152mm/.006 thouRight exhaust. .152mm/.006 thou
I have never measured these before but I am worried about the Horizontal Right Inlet .254mm which is way out of the limits. What dou you think any suggestions gratefully accepted, Regards Neil
If you had no problems before you started the service. Continue on with the service. Change the shims to bring the valves into spec. If your worried, once it’s back together you could do a leak down or compression test, to ensure the valves are sealing ,(IE it hasn’t stuffed the valve seats). If your totally paranoid there is a valve problem, remove the head and check it first....IMO as long as it was running fine before you started this and you were not chasing a problem, simply adjust the clearances and get back to riding.
Reactions: t-bills
Discussion Starter #10
Thank you for your prompt reply tiDuc. I did do a simple test and replaced one spark plug into the head and did the old finger in the other plug hole test by turning the wheel, there seemed to be greatly increased resistance in turning the wheel due to the compression, so hopefully it might be OK. Regards Neil
Discussion Starter #11
Is there a Ducati special tool for inserting the half ring collets to hold the opening shims. I checked in my manual and can't find one within the engine section of special tools. Darn pesky valves want to go down as soon as I put the shim in place. I have tried the bent long nose pliers, but not real good. Good news is I have found a place in Melbourne that makes both opening and closing shims in half thou increments for about $9 AU each.
Sophomore Member
I use a flat blade screwdriver. I put a dab of grease on it and stick the half ring to it. It’s reasonably successful.
I do it exactly the same way, except I use Vaseline...it’s super sticky 😁
Discussion Starter #14
Thanks for your replies I tried the grease thing and it worked OK but my problem is keeping the valve stem up to it's full height without dropping down as soon as the opening shim is placed on the stem.
This video from BikeWorld on their Desmo RR rebuild might be useful, I've never done the job so maybe I'm thinking it's related when it's not (apologies if this is the case)
With the head still on the bike, I’ve got a couple different sets of long handle needle nose pliers at different angles. I use that to hold the stem down low near the guide while I slide a stubborn shim onto the stem. It’s usually just a small burr on the top of the stem, once the shim is on, the valve normally stays up....with cars I always hook an air hose in place of the spark plug and use air pressure to keep the valve stem up...with springs you can not get the needle nose pliers in there.
Reactions: t-bills
I use a pair of long nosed hemostats clamped onto the valve stem down low at the valve seal. Wrap the jaws with electrical tape so you don't bugger the stem.
I also use the "grease on a small screwdriver" trick to install the half rings. I'm not sure if the '15 is the same as my '11, but there's an oil return hole in the head you should plug so a loose half ring doesn't find its way to the engine internals.
Discussion Starter #19
G'day, been away for a few days but today I got to do the full measurements on the bike for the valve gaps. I have tried to work out what shims I will need to replace the existing ones to get the correct gap. Math was never a strong point especially when the decided to mix in the bloody alphabet with the numerals. First question I have is with the closer gaps should I be looking to go for .05 mm or the 0.1 gap. And with the openers is it best to go with the .13mm gap or the .18mm gap, or maybe just find a nice handy mid-point.
An example of one of my closer measurements the gap is .127 mm (.005 thou), and it has a 3.30mm closing shim. I am doing my measurements as per the manual and not doing the loaded/unloaded thing. so what is the equation to work out what shim I require to get the gap to .05mm, (.002 thou).
The really bad measurement is on a closing valve shim where I get a gap of .280mm or .115 thou with a shim of 3.30mm. The bloke I am getting the shims of from "Precision Shims in Melbourne can make openers and closers in half thou increments. PS I have tried some of the shim calculating sheets on this site but can't make much sense of them, thanks Neil
1 - 19 of 19 Posts
