Ok, I give.
I just got my pit bull reversible rear stand and its only instructions are which side to use for removing the wheel or servicing the chain.
So the very heavy "pins", which are like 5lb rods, slide into the approp side--got that. But when I put in the one on the right side, I couldn't get it out unless I removed the hub clip (which is something I've not seen before, too). Surely you don't have to remove the clip each time you want to pull the stand out, so what's up with that?
Also, not precisely understanding how the pins are secured into the stand with the clamp and allenhead bolt.
(Insert emoticon of a butt, as I've just shown mine
