I've been chasing down a slight vibration noise I have roughly around 3700 rpm's on my 1000s. I took off my fairing to make sure everything was all tightened up and I noticed that the sensor that mounts to the speedometer support bracket (shown in the picture) has a slight movement to it. I tried to tighten it up a little but it is pretty tight already and I put a good amount of force to it but didn't want to end up breaking it. It has a rubber piece between the sensor and the frame, I assume for vibration. I don't know if this is the cause of the vibration but was wondering if anyone knew if thiers moved a little back and forth as well.
thanks....mf
