1 - 15 of 15 Posts
Labrador-Lance said:
Lance hates to clean and oil chains. It's messy work. So Lola wanted a Scottoiler.
And what Lola wants, Lola gets!
Take a couple of zip-ties and circle the swing arm where the Velcro attachment is upstream from the disbursal nipples. This will assure that the line won't fall off. I use ATF in my Scottoiler. I use setting #2.
Lars said:
I have a Scottoiler, but I dont understand where and how to fill it.
Please tell me before I break it.
There is a rubber plug on the side of the top, with a hose attached to it. You can simply remove the rubber plug and fill the scottoiler through that hole using the tube attached to the filler bottle.
Well sorry to disagree. But it is the 21st century. An oiler? on a motorcycle? Just a shot of chain wax once a week (If you do tons of riding) or once a month for most of the gay riders. NO MESS, and good protection of the chain.
Life is too short to worry !
You gotta be kidding ?
Chain Lube in cans , now that is old-style !
Have an SO fitted and with the optional Lube-Tube featured she did 3500 Mls through mainland Europe last summer without the need for a top-up and no chain wear at all...nearly as good as shaft drive !
For short rides I leave the LT off but it only takes a few minutes to refit.
FYG - On an ST4s you can fit the SO & LT the other side as the remote damper gets in the way but its tidy and no need for the big tank under the rear number plate.
A top accessory for high mileage tours.
I wanted one, and since the flexible/snake reseroir wasn't available at the time, I made one. I believe it's in our Halls Of Wisdom area. Nice, small reservoir, and it works well! I use ATF also. Cost me about $20 for the 12VDC solenoid valve. It fit exactly where I wanted it it. And it does a decent job! 28,000 miles from the OEM chain and sprockets
Chilehead
Yes, but you will wear out your spockets much faster, particularly aluminum.
Tom
2003 998, 2008 HyperMotard 1100S
I couldn't find this in the HOW section... I don't suppose you'd have an exact link for it?
Is this a sexual orientation thing?
Well, I guess I had no idea what I was stepping into when I mounted a ScottOiler on my ST4S, but it seems to function flawlessly for we heterosexual riders, as well.
I have read some very admirable reviews of the "Pro-Oiler" system also, can't say whether it is "lifestyle-specific"... :rolleyes:
guido in Houston
I just had a long conversation with a Ducati repair shop owner about this subject. He did an extensive (this is his story) study on chain wax. Even photographed a chain in action with a strobe light. The findings according to him. The chain wax works fine as long as you don't ride when cold. If the weather is cold the chain wax caused the o-rings to flex until warm and resulted in premature wear. His recommendation was the Scottoiler using ATF.
1 - 15 of 15 Posts
