I’ll try to keep it short. Last year, I had to fix worn valve guides and a minor cylinder score (vertical). I opted for 944 kit while at it. All done, and about 4000 miles later, I had badly scored cylinders (both). I found a good used cylinders and pistons, and new rings, and went back to stock bore. 200 miles later (still breaking it in), another scored cylinder (vertical). When I found the damage to 944 kit, my best assumption was that I screwed up the installation (I assumed that t rings were correct and didn’t measure them, stupid me). When I installed these used set, I went through the checklist meticulously, and I’m certain that parts and/or installation are not the issue. It was also running beautifully till I felt unusual vibration at about 3500rpm, at which point I promptly went back home). Anyway, I just can’t figure out what is causing it. It’s not the issues with the heads or cylinders. I didn’t put actual oil pressure gauge to it, but the oil pressure light operates normally. It never had any indication of overheating, so what could it be? I need to figure out what it needs, so I’d appreciate any input. Thanks,
