For those that are answering that you want a different shape than stock, what changes do you want?
More capacity, different aesthetic, particular style?
The above post is correct about beast and beast R. You can't just get rid of the airbox and stuff air filters on. Its the same thing with carbs or throttle bodies you have to use the right velocity stacks for your motor set up. Change your cams may need a different set of stacks. Found that very true in VW bug motors.My experience with other bikes is that eliminating the airbox can result in a drop in performance. Is there an airbox eliminator kit that works well on the 1000DS motors without compromising streetability?
I was beginning to think that I was the only one who felt this way.same "exterior" shape (appearance), but i would like to see a tank that requires airbox removal and uses a lot of that space (leave space for TPO Beast) for more capacity. i believe there should be enough space to get about 5 gallons.
personally i love my tank shape, i like the gas cap, dont mind the fuel pump etc... i just want aluminum and more capacity.
Way ahead of ya...was working on it last night. Definitely doable.Bruce,
How difficult would it be, once we have the scans, to generate two different tank bottom panels. One stock, and the other with a bowl shape for those that want to have more capacity at the expense of the airbox removal?
Since, I'm assuming, that the bigger cost for the tooling is for the top part, it would seem to my limited understanding that the bottom could be more modular?
This is assuming that there aren't problems with the shape and the fuel getting to the pump pickup.
Thanks
