So i finally got the bike on the dyno and im going again this weekend.
We are off to try out some diffrent intake funnels and stacks, the diffrence with my idea from ex tpo and other is that im using the stock airbox. Will post graps of that aswell.
Done to the engine is:
1123cc big bore.
Steel sleeve cylinders.
one off mahle hc teflon coated pistons.
Porting by Erik Larsson at proservice sweden.
1mm bigger intake valve.
DP cams.
Custom airfilter frame with k&n airfilter.
termi 2-1 exhaust.
After we are done with the intake side we are gonna build a "fake" stepped header exhaust and go of to the dyno the experiment with lenghts and dia to get the best result, but that is more like early autom job.
the engine is amazing and pulls soo hard and the bike is a crazy ride but more is to come.
I have thrown in a comparison with a hypermotard fully mapped, 2-1 system and dp cams. which i think is a fair comparrison since its a 1100cc engine.
Both bikes are from the same dyno bench and from same tuner so you can tell the diffrence.
i have a feeling this engine can deliver more
1123cc big bore.
DP cams.
termi 2-1 exhaust.
