I'm just kitting out my newly purchased 1260 MTS for a spring tour in 2020, being very careful with my money ( Blame my Yorkshire UK heritage) one thing that bugs me is the cost of official Ducati accessories, for instance they want around £500.00 for a rear top box system. ( Most manufacturers play the same game, BMW being the worst )
However, Givi market a sub brand called Shad, who offer a much better value alternative. Unfortunately their fitting kit adds about 4.5kg of weight alone, coming from a 200kg GT1000 Sport Classic, I'm trying to keep as much weight as possible off the bike so I sent the fitting kit back and came up with my own solution which others might find useful.
Luckily the MTS comes with a nice large rear grab rail which acts as good support for a base plate. I drew up a template out of cardboard, transferred this to some 19mm plywood and cut it out with a jigsaw.
The template also got marked up with holes drilled so that heavy duty cable ties could secure the base plate to the hand rail, both on the sides and rear, as you know these things are incredibly strong so no issues with strength.
I also covered the top of the rail with some self adhesive neoprene to protect the rail itself.
I then made a couple of 3mm aluminium plates to fit in the bottom of the top Box, these distribute the load over the bottom of the box when the securing bolts go through to the base plate.
It may help to view the pictures for clarity, but it works a treat, upsides are that it saves around 4 kgs of weight and the cost of the fitting kit, which was about £125.00, you could use any make of top box, you're not restricted to one brand and you could, with a new baseplate fit it to any bike with a suitable rear support and you keep the bike completely original after removal.
Downsides are; as the Top Box is fixed, you have to use a dry bag to remove your stuff at the end of the day, it won't suit owners who must have the official kit, or don't like the DIY element of it, you do need to drill 4 small holes in the bottom of the top box so resale value of the box will be hit but secondhand boxes are cheap anyway.
For me the weight saving alone is worth it. Hope this has been of help to like minded souls.
