Ducati 1199 Panigale rear sets from Sato Racing allow you to choose from 4 vertical mounting positions, which are all 25mm further forward compared to stock. The first two are 5mm and 15mm higher than stock, and only allow the standard shift pattern. The second two positions are 25mm and 35mm higher than stock and allow standard or reverse shift. An optional spacer kit is available that moves the rear sets back either 5, 10, or 15mm (sold each). Quick shifter optimized design.
Sato Racing Rear Sets are precision CNC machined from the finest billet aluminum for incredible strength, light weight, and long service life. All models feature multiple adjustments to provide the rider with enhanced feel and control (the number of adjustments varies by model).
Foot pegs are solid mounted (non-folding) and feature a knurled pattern that offers grip without destroying boots or leathers like other brands. Foot pegs also feature a delrin plug at the end to prevent injury or puncture in the event of a crash.
Standard delrin toe pieces on the shift and brake levers offer three positions of adjustment to accomodate different sized feet. Optional folding toe pieces are available seperately. Shift and brake levers have integrated double stainless steel bearings for clean, smooth and accurate movement under all conditions, without wobbling.
Available in your choice of gold, silver, or black anodized colors, Sato Racing Rear Sets are the finest quality high performance foot controls you will find on the market! Once you see them and experience the difference, you will never want anything but Sato Racing Rear Sets on you machines!
Most models include both shift and brake levers, where noted, a lever may not be included (some European models), but available seperately. Stainless steel hardware is provided for all fasteners, as well as heel guards to prevent the boot from contacting the chain, swingarm, or tire.
Most Sato Racing Rear Sets offer standard and reverse (GP) shift patterns - with noted exceptions. Please contact us with any questions. A full range of replacement parts are available, as well as complete half sets for most models for easy crash repair.
Click here to order - or call 800.645.6521
