I want to use this weekends track day to try to dial in my D16RR. Straight line stability was iffy until I added 2 clicks to the steering damper, the bike also has a small habit of running slightly wide at corner exit, probably becasue I have too much sag at the rear of the bike. Other than 16.5 wheels and KR106/KR108 slicks the chassis is set up as delivered (which is probably less than optimal with the wheel and tire changes).
Anyone have any useful guidelines on setting up the chassis of the D16RR? Even basic sag numbers would be useful. Mr. Stoner is not returning my calls.
