Its alive!!
Its all good to go now!
The provided kit is excellent ... comes with all the connectors and parts you need. buy the additional piece that seals the wires coming out of the case, it is a nicely machined piece and replaces the stupid plastic piece that you will surely break while removing from the engine. I had to switch out the rear cylinder header to one with a slightly different curve so it would be far enough away ... check this before you order.
I have rode the bike to work and back a number of times already and there is no issues what so ever ... althought it may be a placebo it seems like the bike is making A LOT more power .... maybe my bosch units were worse off than I thought.
Here’s the story. It’s a 1974 GTS with a Desmo engine/wiring harness/headlight/dash out of a later 70s 900SS.
The "victim":
My previously installed dyna coils:
Bracket previously made to hold Bosch ignition modules (it will work perfect to house the new electronic ignish):
The much required "box of random wire" that’s required while doing any electrical work on these bikes!
(Don’t cry ... no duke harnesses were harmed during the creation of that box)
There are 2 things that you will
HAVE TO HAVE TO HAVE TO make/get before starting this project:
1. Clutch case puller
You will be pulling the left side case on and off many times.... and I'm just going to assume that no one here wants to beat the shit out of their case.
Bevel heaven sells them for $80:
OOPS! Something went wrong here. Click the HOME button top left.
But really all you need to do is take an old case plug drill and tap the middle ... then take bolt round the end of it and you have your self a sexy case puller for much cheaper.
2. A timing tool
While doing the final adjustment it is impossible to use a dial indicator to find true TDC on the horizontal cylinder. If you read the instructions on their website you will understand what I mean (
Digital Ignition ZDG3 Ducati Bevel Drive). Use the timing tool to accurately see when the "red light" turns off. I tried with a dial indicator and it’s just not possible to see where the piston crowns at the top.
Here’s bevel heaven's:
I have one so I didn’t consider making it .... but the horizontal piston is at TDC when the marks on the end of the crank line up with the little "tick" on the outside of the case. as seen in the picture below (the plug in the top left also needs to be removed to take the pickup plate off... do it before taking the case off the engine .... I struggled on a bench to do it and finally put the case back on the bike to crack it loose):
NEXT
Follow the instructions for installing the pickup plate and the initial set up of the new wheel.
IMPORTANT NOTE while installing the center steel piece on the crank shaft I thought the woodruf key would not fit into the slot when i measured it with a caliper ... it does, its tight (good kind) ... and the piece is still removable if need be.
Here is a picture of the initial set up:
Sure enough the red light went out about 10 degrees before TDC. Some quick math told me that I needed to rotate the wheel about 3mm counter-clockwise (3mm where the arrow tip meets the center). So off came the case ... adjusted.... back together and test again.... Continue repeating this process till you get that sneaky red light to go out at exactly TDC ... I got stupid lucky and got that thing dead on the 2nd try.
ANOTHER EXTREMELY IMPORTANT NOTE THAT ALMOST MADE ME HAVE TO START THE ADJUSTMENT OVER: while doing this adjustment you will have one of the 3 set screws lightly tight so you can juuuuust rotate the wheel with mild resistance. Once you have the wheel in the right place ... you have to pull the cover off again to tighten the 3 set screws with locktight .... It may seem obvious but
TAKE OUT ONE OF THE OTHER SET SCREWS OUT FIRST!!!!!! if you take the one that is slightly tight out first the wheel will rotate slightly and you will need to redo the adjustment procedure.
One other thing ... the wire that comes from the pick-ups is fairly long ... and the instructions say not to cut it so I looped it towards the back of the tank, if someone else has completed this set up please let me know how to properly cut it down.
Then you are really done.
Dont Forget to bend the washer back over the nut!!!
There are a few more pictures I will post of my final wiring placement etc.
If you have any questions let me know I am more than willing to help you out!
