1 - 2 of 2 Posts
I have having an issue with my clutch after installing an STM slipper clutch, clutch was not fully disengaging when pulling the lever to the bar. I bleed out the clutch to see if that helped and it didnt. I pulled the clutch out and inspected correct assembly as per directions, reassembled. Now that its back together, key on, bike in neutral, pull lever, hit start, just a spinning noise, no cranking. I checked the start sequence for voltages and I get power to the starter when I hit start. What can I check next? Is it possible the starter gear is mis-aligned and not able to engage?
1 - 2 of 2 Posts
