1 - 2 of 2 Posts
Hey guys just wondering if anyone knows how the fitment is for the S4RS Ohlins on an IE Supersport? I know the fork diameters will work, but I can't seem to find any definitive info regarding the fork lengths. The forks are shorter, and I am thinking I can fit the forks and use under triple riser clip ons. Am thinking Woodcraft or Motowheels risers. Maybe 2 1/2" rise?
I am going to do a radial brake conversion, but am also trying to determine wheel fitment. I also have a Monster EVO front wheel sitting around which I think will fit, but am not sure about rotor offsets.
Thanks for any info!!!
Hi,
Öhlins fork from M1100S are roughly 4 cm shorter then 1000 SSie showa.
With the 1000 SSie 5 spoke rim with 6 bolted brake disc, 15mm offset disc is needed.
There are two versions of the Sport Classic Clip On you could try.
First gen was lower and next came a higher version similar to ST, both mounts under the triple.
Reactions: Broombah
1 - 2 of 2 Posts
