Hi!
Does anybody know If I could use the ECU of an S4Rs on a Standard 998?
Thanks bye
DD
I don't think so, you will have to use the key and the dashboard from the Monster due to the immobilizer.
Or send of the ECU to have the immobilizer "removed".
Hi!
Thanks bye
DD
It dependes which ECU you have. If the S4rs is a 59m ECU you can use it but first you have to flash the ECU with the correct map and switch off the immo. I do think that s4rs has a 5am ECU and if so it does not work
Jocke.
Sent from my SM-G935F using Tapatalk
