The time came to refresh the heads of the old 996. Looking at the cost of replacing 8 valve guides, It was nearly a wash to pick up a set of low milage s4r heads and put them on the 996.
It turned out easier than I thought. Heads, timing belt covers, timing belt backing plates, and 93 tooth timing belts were the only things I needed to accquire.
The banjo oil fittings in the heads needed to be drilled and tapped from M8 to M10 x 1.0. The head studs needed to be shortened by 10 mm give or take (have dremmel will cut) Installation was straight forward. Squish setting didn't change. The intermediate exhaust pipe moved back slightly and one small screw on the verticle head near the timing mark, which I don't know what it was for, need to be removed so the oil breather tank would fit.
Put it all back together and she came to life on the third revolution!
The final pieces of the puzzle to figure out are the radiator bracket and V piece. But she's back on the road.
