So I bought S4R forks off eBay and stripped them to make sure all was well. Glad I did because there was some craziness inside.
The manual says the spring length should be 270mm. Mine measure 365mm. That's quite the difference!
On the positive side, both springs are the same length, but one of the spring collars had been jammed up, ramming the spacer above inside the top of the collar and splitting it by a couple of inches!
No idea how that happened. Other side was fine.
Suggestions appreciated.
