I know that the 996 uses the 1.6 ECU, does the S4R use the same ECU or a different one?
JDuc · Registered Joined May 23, 2005 · 1,195 Posts Discussion Starter · #1 · May 3, 2006 Only show this user I know that the 996 uses the 1.6 ECU, does the S4R use the same ECU or a different one?
E ericS4 · Registered Joined Apr 9, 2004 · 51 Posts #2 · May 3, 2006 Only show this user The S4R uses the Marelli 5.9 unit.
JDuc · Registered Joined May 23, 2005 · 1,195 Posts Discussion Starter · #3 · May 4, 2006 Only show this user thanks!
