So I'm trying to disable the immboblizer on my duc using tunerpro and IAWdiag reader/writer. Im using the xdf from Guzzi/IAw diag (5AM S2-1000R DP V1.28) which I'm assuming is the DP ecu xdf. Anyway I've downloaded the .bin file and uploaded it to tunepro and unchecked both lambdas (4D144 & 4D145) and immob is still active. Ive searched the forum and found some info on other monsters, but the immobilizer addresses arent the same for the 1000 DP ecu. If anyone can give me some directions here that'd be much appreciated.
Thanks
Thanks
