1 - 13 of 13 Posts
This week I replaced the original headlight on my 2007 s2r 1000 with one from a 696. I know a lot f people have expressed their dislike for the new lights but I thought it would look good in the old bike.
What do you think?
I like it, looks good.
I'd also like to see what an old-style headlight looks like on a new-style Monster.
Blame the universe not the tank!
Guess I should have asked this in my first reply...
What mods were needed to wire it in, plug n play?
Did you use the monster bracket or the 696 bracketry?
I take it that the windscreen would look funny since the stock light is of a different dimension?
Discussion Starter #7
Other than the wiring which needed to be altered in a minor way (join Blue cable with yellow with black line, the other three match perfectly), the only thing I had to do was to cut the aluminum bracket at the top. It was very easy because the aluminum was very soft and light. The mounting bracket I used was the one from my s2r which worked perfectly. A guy I know from a different board does use the fairing but in order to use he had to remove the top plastic trim piece. To tell you the truth, I did not like the wayit looked with the fairing. But then again, I have never really liked the look of the fairings anyway.
1 - 13 of 13 Posts
