1 - 7 of 7 Posts
So my bike really never gets wet and when i went camping she was parked out in the wet mist/fog for 2 mornings. Now when i stare at her ass i see rusty areas on the header:mad: Wipe it off? Scotch brite it? Or use chemicals? Its just an eye sore:(
I Scotch brite every couple of hundred miles just to keep my exhaust pipe looking new and then wipe it down with a lilttle WD-40 incase I put any finger prints on there. You dont want to burn/imprint fingerprints on the exhaust. I then turn the bike on and let the WD-40 burn off. It's a smiple job.
Thanks! Its been bugging me ever since i got home. Its not a pretty header by any means but rusting looks so blah.
By the way, on an somewhat related note, are your pipes seam welds just garbage coming out of the factory there in Ducati ? I've seen much better welds coming from high school
My 1098S SF was orginally from NY and I'm guessing it was stored outside in the snow. I had plenty of rust and other weird stains probally from salt. I ended up using a Scotch pad and it works like a charm. If you keep scotch pad it a regular you can keep your pipes looking new for a very long time. I hate the bluish or burnt look on an exhaust. Have fun .
I had mine ceramic coated black. It was under $80. But I didn't go all the way to the header that bolts to engine b/c you can't really see it anyway.
1 - 7 of 7 Posts
