Generally speaking if Windows 10 will let you install it, it will run. Windows may interrupt the install and ask you if you want to install it in Windows 7 or XP mode.
The biggest problem might be 32bit program, 64bit Windows. That program probably wants to use its own USB to Serial drivers so you might have to play with that.
