1 - 7 of 7 Posts
Just doing the annual servicing on the ST2, and noticed the injector connector boots have seen better days. Does anyone have a part number for them?
Super Moderator
I don't think Ducati lists part numbers for these boots. Similar items are available from supply shops that sell the connectors (google AMP connectors and waterproof boots).
I don't mind taking the connector off and replacing the boot, was wondering if there was a amp part number as they are all different sizes.
Looking through the catalog I linked under connector accessories, I found this boot. You'd have to measure yours to see if it will work. PN is listed on the drawing. The size of this part looks as if it would work on the TPS plug. It's a start. No idea where you can order from.
Discussion Starter #7
I'll take a number off the connector tomorrow, I've noticed most of the booted connectors are like this. I also need to replace the TPS connector as it's green on the centre socket. I've managed to find them though.
1 - 7 of 7 Posts
