1 - 10 of 10 Posts
they come with mounting hardware. so you should be good. I'd replace the tubing while you're at it, but they are very simple to install.
edit: make sure you get those that connect from the side and not from the bottom... otherwise they will be sitting quite high over the bars and it's not ideal.
Do these just fit right on over existing or do you need other parts to hook them up?
you may need to get a couple new washers as the OEM bolt on the duc did not fit the bracket hole on the Rizoma mount on mine.
If you really want to get a clean look, replace the clutch side union with w/ a horizontal union which is also easy to do.
other than that, plug and play.
Do you have any pics?
Check the PakBikes website...
Phil has got both reservoirs installed on his PS. I am, on the other hand, having all three reservoirs (rear brake, front brake, and clutch) delivered today from Monster Parts.
Hoping to have them installed over the weekend. I'll try post some pics then.
Cheers.
1 - 10 of 10 Posts
