1 - 12 of 12 Posts
Right i took the plunge on a whim yesterday & ordered some Rizoma reservoirs, Amazingly they came today so i fitted them , I reckon they look ok & wont wobble around as much as the standard plakky ones.
Not a bad item to fit , just took time to bend/cut the brackets. My fathers day Workmate proved an excellent pressy. It is a great extra pair of hands.
Discussion Starter · #4 · (Edited)
If you are careful like i was . you can remove the originals by undoing them by the bracket from the lever & turning them upside down , then remove the clip & your away.
If you dont touch the lever your can do all you work, fit the new ones, top up with fluid to the line & a gentle jiggle on the lever to prise out the air in the tube so no bleeding required. Just keep a rag under the one your working on just in case any drops out.
I think it looks great. I just took two black wrist sweat bands and put them over the containers and it looks great. It probably is the cheapest mod I have ever made. 3.00 at the local sports authority. ;) Somday soon Id like to set up my bike likes yours. Great work!!
Word of caution: keep a close eye on these. There were several complaints on the Triumph forums about Rizomas leaking and spraying fluid all over the tank.
Just a warning...
Discussion Starter · #9 ·
Just a warning...
Thanks for that., I,ll keep an eye out. Just interested did they leak from cap or underneath ?
When I had them on my S4Rs, 1 of them was leaking around the site glass.
1 - 12 of 12 Posts
