1 - 9 of 9 Posts
Does anyone know of an available riser/clamp that will fit a GT top triple without modifications and will allow the use of tapered handlebars? Seems everything (Rizoma etc.) requires the recess in the triple be made larger or the base of the riser turned down a little. And no I don't want to shim the riser up with washers or a spacer....
Thanks!
My best guess would be ROX risers.
Thanks!
LSL Bar Risers ?
I dont know if they fit in the GT triples without modification. Unfortunately when I asked Spiegler if they would fit, they didnt know and couldn't be bothered finding out.
Maybe other dealers are more helpful ?
How much taller do you want them?
I can make a production of them in about a week or two
Thanks!
I don't want to go any higher, I want to mount 1 1/8" bars and I don't want to open up the recesses in the triple to accept Rizoma risers. And I don't want black which is all Rizoma seems to offer.
Thanks!
Choice is make a riser to accept a 29mm bar based on the stock riser style or Modify the Rizoma. Strip the black anodizing. Machine down the bottom of the risers so it will seat in to the GT triple clamp. Polish and reanodize silver. This will achieve what you want.
Either way it will cost about the same in the end.
Thanks!
Discussion Starter #8
PIA! I guess you have made me realize how much I adore my current 22mm bars.
Reactions: Riderjeff
Mod the Rizomas
Just mod the Rizoma risers, it's easy if you're willing to accept a 98% solution instead of 100% like I did.
Put a bolt through the riser hole and put it in a drill to spin it. Gently hold a file against the bottom. You only need to take off about 1mm off the bottom 1-2mm. Tape over the top and give the now exposed bottom a little spray with dark paint. You can't see it once it's recessed anyway.
I did it this way and you don't notice it. The tapered bars are awesome on the GT.
Cheers,
Pete.
1 - 9 of 9 Posts
