It actually IS in a hole in that pic... but it's hard to tell because the pin is almost the same diameter as the pin.thx all!
but strangely I saw this pic where the pin doesnt sit in the hole at all
but will try it today
In this photo, the "pin" portion of the clip is sitting in the hole. It's supposed to be completely through the hole. Then the clip will fit correctly.I noticed the retainer clip on the rear wheel did not hug the nut completely.
Yes. And a really big one. Some owners have reported finding that nut only finger tight because the tech got distracted, forgot to torque it, and just put the clip over it.Safety issue?
you have a 230nm torque wrench to lend?Yea the pin is not through one of the locking holes... that's actually the only bit of the whole thing that does anything useful. Look for one of the holes that is inline with a gap in the nut and rotate the clip to line the pin up with that hole... it should pop through.
Before you do that you might want to check torque on the nut... it shouldn't loosen even without the pin (if it was torqued correctly) but without that pin there's nothing preventing it from loosening if the nut was not torqued correctly.
thats fucking shocking tbh...to hell with waiting till my next Desmo service...Yes. And a really big one. Some owners have reported finding that nut only finger tight because the tech got distracted, forgot to torque it, and just put the clip over it.![]()
Yea a big safety issue. If you don't change your own tires it's worth checking the tech's work if you have a torque wrench... if they don't torque the nut correctly the other bad thing that happens is that the nut backs out and locks the pin in place - then the only way to fix is to get a new retaining clip and cut the old one off so you can fit the socket. Then you have to tighten the nut a bit to free up the last bit of pin.Yes. And a really big one. Some owners have reported finding that nut only finger tight because the tech got distracted, forgot to torque it, and just put the clip over it.![]()
that does not sound logic when I see how many slots there are on the nut itself...I've yet to find one, when torqued to 230Nm, where the holes in the axle did not line up with a slot on the nut needed for the pin.
I would guess your nut is not torqued correctly.
I had to go buy it specifically for the job... figured it was worth it since the shops around here rape riders on motorcycle tire changes (one charges $70 off the bike... didn't go there twice).I have one dedicated torque wrench that I use pretty much exclusively for just doing the rear wheel nut on these bikes, the one at the top..
He's right... the holes are offset from each other so when you're at the correct torque one will ALWAYS line up properly with one of the slots (which have a different pitch from the holes). I've had the rear wheel off maybe a dozen times and have never had a problem seating the pin properly.that does not sound logic when I see how many slots there are on the nut itself...
He could have tighten it at 229nm or 231nm.
Those small differences could result in the misalignment of slot-hole.
Nonetheless, that lil sentence made me a lil bit worried.
Now I gotta check if i can losen the nut with my bear hands..
I doubt it, since I've trashed the bike almost everytime I rode it the last 4.500km I rode it in the last 3 months.
Surely I would have died by than? 0![]()
