G
Guest
·I've almost completed installing the Cycle Cat riser bars on my 06 749S but have one issue. The throttle cable routing (stock) causes the cable to become too tight when the bars are turned to the right which than revs the engine without turning the throttle!
I rerouted the cable behind the steering tube to loosen the slack on the cable however this creates a condition which prevents the throttle from operating smoothly.
Has anyone rerouted the throttle cable on their 749/999 for a similar reason and if so how and where did you run the cable?
Thanks,
Rob
Thanks,
Rob
