These tach units are very sensitive to electrical failures elsewhere on the bike and items going south.
Check your Regulator Rectifier connections. Check battery. Check the stator (keep in mind the stator can fail when hot and show good when cold.) Check all connections leading to the Tach. I had a bad battery as the culprit. If all seems to check out, do a proper voltage test at the battery when running at idle and then above 2500. If it is the R/R it will show at this point. Just need to set a priority list of likely items. The Tachs need proper voltage and without same, you'll see erratic read-outs.
If it is the voltage Regulator - Rectifier, get a genuine SHINDENGEN MOSFET FH020AA REGULATOR/RECTIFIER. Available on Ebay or Amazon. Yes, you'll see Mosfet junk for $20, but stay away. You get what you pay for.
BTW, the best one stop shop for RR, other electrical items and advice is
https://ricksmotorsportelectrics.com/
Steve
REGULATOR/RECTIFIER
The regulator/rectifier on your motorcycle performs two functions. The rectifier portion converts the AC power from the alternator into DC power so that it can charge the battery. The regulator ensures that the voltage is delivered within certain limits, as not to damage the battery. Excess power is converted into heat by the regulator to get rid of it. The regulator and rectifier are often together in one unit, but for some bikes (mostly older), they can be separate.
To test the rectifier, you will need to disconnect all of the wires and turn your multimeter to the diode function. First, check the positive diode. To do this, place the positive lead into the positive diode. Then connect the negative lead to each of the stator inputs. The meter should not read anything on any of these. If that checks out, connect the negative lead to the positive diode and connect the positive lead to each of the stator inputs. The meter should now be reading something. The numbers are not important.
Motorcycle Regulator Rectifier
Repeat the process for the negative diode. This time you should get a reading with the positive lead connected to the negative diode while connecting the negative lead to the stator inputs. With the negative lead connected to the negative diode, the meter should not read anything while connecting the positive lead to the stator inputs.
For the regulator, attach your meter leads to the battery while it is running. It should not read higher than 14.5 volts and no lower than 13.5 volts. If it is higher, the battery will be over charged and if it is lower, the battery will continue to drain as the bike runs.
If these tests do not check out, you will need a new regulator/rectifier.
