1 - 2 of 2 Posts
I have a 2012 Streetfighter 848 and I need a new clutch master cylinder. With the lever pulled all the way in the lever slowly looses pressure and the bike slips into gear, and I have eliminated everything else.
I emailed Beuel Heaven to see if they had any rebuild kits but it does not look likely. I am having trouble finding out any information on the OEM clutch master specs, and what a good replacement would be. What size would I need to work well with an aftermarket Oberon slave, and are there aftermarket masters that people generally use? What do I do about the plug if I choose a non-OEM option?
I have mounted a Brembo RCS 16x16-18 on my trackbike. It is adjusted to 16x16, and paired to a Kbike 30mm slave. Oberon springs in the clutch.
I can pull the lever with 1 finger. This works excellent for me.
1 - 2 of 2 Posts
