There's no bulb in the LCD display to replace. It's electro-luminescent. One it goes out, you just replace the unit like you've done and junk the old one.PaulST4s said:
There's no bulb in the LCD display to replace. It's electro-luminescent. One it goes out, you just replace the unit like you've done and junk the old one.PaulST4s said:So, the backlight on my LCD went out last fall. I just picked up a new one on eBay, and I'd like to see if I can get the old one fixed. Has anyone taken theirs apart? There are 3 screws on the back which I removed, but it didn't want to come apart easily, and I didn't want to break it.
Turbo said:There's no bulb in the LCD display to replace. It's electro-luminescent. One it goes out, you just replace the unit like you've done and junk the old one.
Do you mean the speedo and tach? To be honest, I'm not positive but I expect they use bulbs. I think only the LCD panel is electro-luminescent.stryder said:Do pre-04 St instrument pod's have electro luminescence, or bulbs?
That would be the likely place! If water pools anywhere, it's at the bottom of the display. Sealing around the trim-display interface with silicone might be a good idea.JohnBoy said:Where do you folks think the water is getting into these units?
I had this happen to me once and it took about 6 months before the moisture disappeared altogether.
My guess is the water is getting in on the bottom of the face between the screen and the trim.
Maybe silicone?
Just a small point, but we have been talking about the 2002 ST LCD display here. It's not the same as the 2005 instrument pod. The 2002 instrument cluster consists of 2 round analog gauges with the LCD unit mounted below them.stryder said:Buddy of mine with a MTS, same instrument pod, had moisture in his after riding through a torrential rain fall, and when he got home, pulled it, pried it open, (there appears to be pry spots) applied some type of silicone sealer, fitted it back together and states it's been water tight since. A member of this site from England stated in another thread his dealer did much the same thing and called it "the fix." I've ridden in heavy rain once, but only for about 20 minutes and mine stayed water tight, but does condense moisture if experiencing rapid temp changes. I'm going to take a look at mine and if I can pry it apart, seal it with silicone.
Excellent post Grim. This has given me the inspiration to prise mine apart and see if I can get it working again - my LCD is totally dead.grimah1w said:Grim here, successfully repaired mine after I saw moisture inside the window, then noticed the display failing. Here is link to my web site where I detail the process.
http://www.ducati-st4s.gotdns.com/M...sues.htm#5issue
You should try it before spending the cash on a replacement. Good luck!
FWIW, BOTH senders went bad on my 1998 ST2. These were the first items that I replaced on my ST4s, when I bought it. The readout is absolutely believable. And I've verified it using an optical pyrometer.Just to add, I had the same problem when I got my 4s first.
I had to wire in a shunt between two of the display legs to restore full functionality, but even so, there was some corrosion on the PCB and it affects the temperature read out.
The display is fine, but the temp over reads significantly. For example, when the fan kicks in, the temp displayed could be as high as 110.
The higher the reading the further it appears to be out, suggesting that the corrosion has increased the resistance of the circuits that interpret the signal from the sensor.
In town with ambient temperatures of anything more than 15c, I regularly see the 120c flashing warning, but when I thought my bike was going to melt, I went and had the diagnostic hooked up and the codes read.
There were no temperature warnings at all and the guy (Bologne trained) was able to turn the fan on and off as normal via the ECU.
It turns out that the even swapping the sensors made no difference.
He explained it by saying that the little gubbins in the ECU that takes the electrical signal from the coolant temp sensor and turns it into a signal to be read is vastly more accurate than the one in the LCD display. He said they were unreliable at best. The water ingress seems to have exacerbated the problem. His advice was ignore it.
A
