I need some instruction on removing the rearsets on my S4RS. Do the large nuts on each side (that are in line with the swing arm axis) need to be removed and if so are they 24mm or 25mm.
Thanks
Thanks
Access the following FTP server to download the shop manual:I need some instruction on removing the rearsets on my S4RS. Do the large nuts on each side (that are in line with the swing arm axis) need to be removed and if so are they 24mm or 25mm.
Thanks
