Has anyone found a good way of removing the Output Shaft Needle Bearing, the one that the Clutch Push Rod runs on?
I want to replace mine because the Push Rod was bent and I’m sure it’s not left the bearing in perfect shape, but the bearing is visibly ok and it is turning ok too. So for now I’m going to leave it and just pack it with plenty of grease, though I will change it in the next few weeks.
