Anybody have the link for the guy that sells the reflective tape that fits the rear of the st bags? Looking for the stuff that's inconspicious until light shines on it....Will
http://www.ducatidesigns.com/inc/sdetail/2497Although it wasn't part of your original question, if you want to boost your visibility, consider replacing your turn signal and brake bulbs with LEDs. Yikes! What a difference! Very easy to do.
$25 is a good price for that, he doesn't say if it's 3M or not though but being in the sign business I've used a lot of Avery (a bit cheaper) without a problem. It costs me about $17 a yard at 24" and that looks like the better part of a yard.
I don't have the pannier set, rather the checkered helmet application. Same stuff from Applied Graphics. I applied them to both my helmet and panniers. Reflectivity is pretty good yet not obnoxious. I find some of the stuff out there too bright. Especially something as large as the pannier setup. I also like how it's black when no light source is pointed in its direction. Subtle until lit.$25 is a good price for that, he doesn't say if it's 3M or not though but being in the sign business I've used a lot of Avery (a bit cheaper) without a problem. It costs me about $17 a yard at 24" and that looks like the better part of a yard.
There are different levels of reflectivity, that's probably what's called engineer grade, the prismatic stuff is quite a bit more reflective but maybe too much for this application.
