There is a thermostat inside one of the tubes. That will not open up until you reach a certain temperature. Start up your bike and let it warm up. You also need to burp the tubes between the engine and the radiator by squeezing them while the engine is running to get all the air out of cooling system.
When the engine gets hot, do not open up the radiator cap. The pressure inside will force the hot fluid to burst out. Only add fluid to the reservoir.
-Fariborz
-Fariborz
