I did these for my black SFS and I'm not sure about the colour scheme - comments?
Curious to see if you like them after a while and get used to them. The red color is not too "bright" - it adds a nice touch.I originally made them in black (see photo) by cutting a hole and "skinning" the original part. Then I got the idea to add a bit of colour to them so dyed some epoxy and this is what turned out. I put them on the bike and will leave them there for a while to see if I get used to it - it's different, that's for sure..... If I like it after a while, I may red coat the side radiator protectors to get more of a "tie" to the rest of the bike...
I don't sell these as I am not set up to do it on a commercial basis. These are pretty easy to make. The carbon fibre is laid over the original part and "painted" with epoxy. Once it hardens (24 hours) dremel and sand to finish and then clear coat. If you want coloured carbon, you can put dye in the epoxy (like I did with the red ones) or you can have it sprayed with candy apple paint.
Go to www.sollercomposites.com to get materials....
