As I am working through my 900ss ie project, I am thinking the engine is going to need a refresh. Its former life was a racebike, and used pretty hard. While it runs and doesn't smoke, there is oil sweating from the vertical cylinder. The previous owner did rebuild the engine, but re-used the gaskets (!).
Question -- I see that Athena sells a gasket kit for the 91-98 900ss engines, but I am wondering if this kit will also work on a 2002. I know in 1998 the 900ss moved to internal oil lines (I had an FE in a past life...) but realize ultimately the engine has changed very little over the years.
