Why not call Ohlins USA in NC and ask if they can change them out for you. I had a set of RTs w/ axial brackets on my 999. The radial RT bracket was no longer available thru Ohlins so they offered to install an OEM 999R radial fork bottom. They just moved the rebound adjustment location. Why couldn't they use an OEM radial Ducati fork bottom?. I sent the forks down to them, they did the change, and serviced them. Turn around in a few days.
