I am assuming, and I hope correctly, that you are speaking of the tail assembly being loose and not just the turn signals.My rear turn signals are loose. It drives the people crazy who ride behind me.
Has anyone opened this up to try tightening them?
So did I!My rear turn signals were as floppy as cooked pasta. I pulled it apart to see if there was a convenient way to tighten it up and concluded there was not. Went with Rizoma tail tidy and signals and am very pleased.
I noticed one of my rear signals was loose the other day. Liberal amounts of gorilla glue seemed to fix the problem. I was too lazy to pull the housing apart to see why it let go. Now I'm noticing that the clear plastic part of the other rear indicator is no longer flush to the mounting back, so the next ride in the rain should make for a good stress test of that bulb.On my bike it is the turn signal themselves that are floppy, not the assembly.
Sounds like there is no way to tighten these.
Thanks.
They need to be more snug somehow. They bounce around and look cheap when rolling. Where they are connected to the tail is fine on mine. Just the tips where the rubber disc type thing happensOn my bike it is the turn signal themselves that are floppy, not the assembly.
Thanks.
