rear sprocket on MS4R
1365 5
Is our only option on this bike either a factory replacement sprocket or to go with an aftermarket carrier and sprocket?
Do the aftermarket sprockets not fit the stock carriers?
1 - 6 of 6 Posts
ok guys - thanks for the info, but I'm asking if anyone makes a replacement for the stock carrier?
I know I can get an aftermarket carrier and sprocket to go with it.
again, I'm asking if anyone makes an aftermarket sprocket for the stock carrier.
We used to carry the direct bolt on sprocket from STM and Ducati Performance--but they have discountinued them. (We still have a few in very limited sizes).
We found the evo quick change carrier and sprocket was the least expensive and most versatile option now--and they have the little anit-back off plate built in to protect the swingarm...
there is no stock carrier, the sprocket is a one piece unit that the cush drives fit into. so your options are really only the std steel (heavy!) sprocket or a QR type carrier and suitable sprocket. i use the afam type as afam sprockets are good quality and easily sourced. once installed, sprocket changes are easy as.
1 - 6 of 6 Posts
