1 - 7 of 7 Posts
I have a 05 Ducati 749, the rear sprocket flange can be pulled up after the nuts are tight on the sprocket, is that supposed to happen?
With the sprocket side facing up while rim is laying on it's side, I can lift the sprocket flange separate from the rim an inch or 2
it lifts off the wheel. ideally you hold the pins and make sure they're tight in the carrier then tighten the sprocket nuts. pull it out, loosen all the nuts off, tighten the pins in the carrier then retorque the nuts.
1 - 7 of 7 Posts
