I will replace my shock with a Öhlins unit.
I have found that a DU0101 would be the best match, but there are few for sale at reasonable a price.
Would anything from anothe model fit? I have a offer for a ST4S shock, I know it is different with external chamber and so and
I can adapt for that, but would it be a possible swap?
Any other suggestions?
Thanks.
The Ohlins rear shock that fit is the DU235, I have one on mine.
They were originally mounted on the 1000, so it is possible to find some
Super Moderator
The ST4 uses a linkage type rear suspension set-up. The valving and spring rate would be way wrong for your 900.
