Anyone know what effect would the fact that the rear shock has a droop spring have on the static sag measurements please?
What the hell is a "droop spring?"
thanks for your help......:D
its an internal spring that slows down the shock from topping out at full length ie when your wheel leaves the ground.....
i had heard that when one is fitted it may effect the static sag measurement...
You'll need to remove the droop springs coilbound length from the original preload setting to avoid affecting the sag.
Assumes the droop spring isnt too stiff a rate..
