1 - 3 of 3 Posts
Is there any foot brake levers out there for a S2R800?
stock lever is very hard to find at times, it's tucked way in under the engine cover etc. Would like it to extend out more, very easy to miss the pedal altogether at times!
Anything out there other than complete rearsets?
I had a similar problem on my 1995 M900.
I suggest you remove the existing pedal rubber and replace with a longer very stiff piece of hosing with the same ID as the original pedal rubber.
In this way you can cheaply extend the pedal width by a cm or two
1 - 3 of 3 Posts
