It's me again... Another 900ss rear brake thread. Thank goodness I don't really use it and the fronts work fantastic!
So last time, about 2 years ago today, I gave up completely and replaced the master cylinder AND caliper. A fresh start. The brake worked, I think (I really don't use it), when I put the bike up for the winter. Now it does nothing. When held down I can still roll the bike freely. So, I did a reverse bleed with my handy vacuum pump. The only problem, no fluid is being pulled out... I took a break to think and went ahead and bled my clutch, and the pump worked flawlessly. So it's the brake. I know I was cracking the bleeder valve enough because just a bit leaked. I took a stab at a normal bleed, which didn't work either. I'm flabbergasted. If the master cylinder or caliper were bad I could still do a reverse bleed, I think... I can't pull OR push fluid through. It can't be blocked, because the pressure from the pedal or vacuum would build up.
What would keep fluid from flowing through the system? I feel like I'm missing something super obvious (work has been crazy AND I'm sick...), so be gentle :wink2:
