Real quick one, was just cleaning up the rear brake lever etc, thought I must note how the spring fits in behind the lever.... just as it came off:mad:. pretty sure I have got it back right now but just wanted to double check. Bit hard to explain but i have one part of the spring on the main support beam of the bracket (there was still a mark there, so I am sure this is right) for the other end the only place I can see it can locate and work is just under the connecting rods that leads back to the slave cylinder. It seems to work fine, just want to double check.
