Rear Brake Failure
2742 12
So my rear brake just stopped working. It wont even hold the bike in place in my drive way. I do not use it all that often but I am still curious why it might have just stopped working.
1 - 13 of 13 Posts
Ok, seriously, get the wheel off, remove the caliper. Then check your pads, my pads separated from the fixed backing. I am dead serious here, it caused my wheel to lock up from friction heating the brake fluid so hot it expanded the lines and made it lock the caliper.
Is there a way i could check for that before removing all that?
check the free play on the rear break peadal!!
if you have adjusted the free play out of the peadal the heat gets transfured through the rearset and binds the master either on or off but mostly on.
this happens on all bikes through the 916-1198n :eek:
Discussion Starter · #6 ·
This just happened for the first time an hour ago. Once the bike heated up the back wheel locked up and the brake lever was stuck fully engaged. So how do i fix this? Because now that the bike is cool, the lever moves freely but doesnt do anything when i press on it.
Come in Spinner :)
You have cooked the pads now when the brake locked on so replace them, flush and bleed the fluid and adjust some freeplay back into the master cylinder pushrod so it doesn't happen again.
Chilehead
You've got too little freeplay, which caused the brake to lock when hot, as the bleed port is blocked (either now, or when things warm up).
Now, you have air in the system, which is why it's not working, and it won't bleed as the bleed port is blocked.
Unless you completely understand what I have written, you really should take it to a shop rather than try to fix it yourself because, while braking systems are not complex (ABS excluded), they are easy to screw up if you don't really understand them, and that is very dangerous!
Tom
1 - 13 of 13 Posts
