As per earlier posts, the headlight on my 900ssie is shocking. I did the HID (eBay) route and low beam was amazing, but high quite poor. This is most likely due to H4 high beam filaments being a few millimetres off the centre axis of the bulb and HIDs that move the bulb only move along the axis, so the high beam position is wrong.
Back to the plot. I got out the multimeter and measured some voltages and found I was losing about 1.8V on high or low from the battery to the light. According to the Daniel Stern Lighting web site, at 14 V at the lamp, it produces 1356 lumens. My reality was 12.2 V, when the battery was 14, so again according to Daniel, I only had somewhere between 800 and 900 lumens. Lets guess it was 850, so I lost 37 whopping percent!!! No wonder we all think the lights are crap.
The reason is the cables are too small and all the connectors add to the voltage drop.
Solution - bypass all the wiring and put in serious gear.
Parts one 5 pin auto relay. one 4 pin, normally open auto relay, one heavy duty H4 lamp connector, about a metre of red and black cables around 6mm2 or bigger if you want, about half a metre of blue and brown cables around 1mm2. 5 female spade connectors for the big cables, 4 female spade connectors for the small cables, a 15A fuse and holder and finally two male spade connectors to plug into the original H4 connector.
I have attached two wiring diagrams. One is for this mod and the other incorporates an extra momentary action switch, which means you can start the bike without lights on (cold cranking days!) then press and release the momentary action switch to turn the lights on, which will go off when you turn off the bike.
Richard
PS I have not given up on HID yet and will work on a mechanism to get the high position right.
Richard
