Well... they are 50mm where the top triple and the clip ons are. but you would have to measure where you would be mounting them, Also... look into using a headlight mount from a monster, they bolt on the lower triple.The sliders? I have searched and cannot find the answer. Need to know for headlight brackets.
Good point on taking measurements. I may actually be using my stock trees. I have some ideas brewing....Well... they are 50mm where the top triple and the clip ons are. but you would have to measure where you would be mounting them, Also... look into using a headlight mount from a monster, they bolt on the lower triple.
That is the diameter at the bottom triple clamp. The forks narrows to 50mm a bit above the bottom triple (depending how you position the forks).For some reason the number 54mm is sticking in my head but I may be confusing the SS with the old GSXR forks. If no one pipes in with an answer by tomorrow I will pull out the calipers and measure the width of the sliders below the yoke and handlebar clamping area for you.
You know, I really should quit be a cheapo and buy a set. A mircle I've gotten this far.I will pull out the calipers and measure.
